ShadeM16's avatar
ShadeM16
Follower
Nov 08, 2020
Upgrading router. Which one?
I am currently looking to upgrade my XR700 router to either the XR1000 or RAX200. I have a med/large 2 story home. I have 4 security cameras around the home connected to wifi using 2.4ghz and occasionally a phone or two connected also using 2.4ghz. I also have a gaming pc that is connected to wifi(5ghz) using the AC1900 WiFi USB Adapter. I have been looking at both routers above but I am not sure which one would be best for me to upgrade to. Thank you for any suggestions.
1 Reply
  • Well this is the Pro Gaming section so I would have to be biased and say the XR1000. Comes with DumaOS 3.0 built in and you have AX WiFi!
