faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
faruk_prlk
Nov 09, 2022Guide
Thanks for your answer, I have the latest version of my xr500 device, modem keenetic omni dsl kn2011, I don't use static ip, I use cat7 ethernet cable, what would you recommend me to do?
faruk_prlk
Nov 09, 2022Guide
Keenetic omni
- Netduma-FraserNov 09, 2022NetDuma PartnerDo you have the XR WAN IP in the DMZ of the omni? If not you will need to do that and it should work
- faruk_prlkNov 10, 2022GuideI opened dmz but where should I write router wan ip into port triggering?
- Netduma-FraserNov 10, 2022NetDuma PartnerYou put the WAN IP into the DMZ on the Omni, that's all you need to do. Don't do anything with ports. See after setting the DMZ correctly whether you get an Open NAT without error.
