faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
faruk_prlk
Nov 14, 2022Guide
Hello, I called keenetic company, I said I need to write wan ip in the modem dmz part, they said that such a thing is not possible, they said that you can do such an operation on the xr500 device, what should I do?
Netduma-Liam
Nov 14, 2022NetDuma Partner
I doubt that's the case, and you can't put the XR500 in the Omni's DMZ from the XR500's settings, that's not possible.
Can you go to the Omni's admin interface and send a screenshot of what options you have when it comes to DMZ settings? We might just have to work it out ourselves.
- faruk_prlkNov 15, 2022GuideRemote connection can provide a definitive solution, if you want, connect and make the necessary settings for both the modem and the router.
- Netduma-FraserNov 15, 2022NetDuma PartnerWe don't conduct that type of support, if you connect to the interface and provide the screenshot as above we can advise from there
- FURRYe38Nov 15, 2022Guru - Experienced User
The user should probably contact the Mfr of this Modem/Router combo unit and ask then for help in bridging this modem fully or if it can't be bridge, ask them for help on configuring DMZ for the XR series router.
- faruk_prlkNov 15, 2022GuideI will enter the modem and share the screen, so we come to a conclusion
- faruk_prlkNov 15, 2022GuideKeenetic company does not share any information about the xr500. I will share the screen, please can you describe it?
Its recommended to ask the mfr of the modem for help and information regarding there product. Not the NG router.
- faruk_prlkNov 15, 2022GuideThey said that wan ip cannot be written into the dmz of the modem, so I am asking for help.
- Netduma-FraserNov 15, 2022NetDuma PartnerAre you able to access the modem interface? If so please take a screenshot of what you see
Did you ask them what is suppose to be input into the modem?
The Mfr should know how to set this up on there modem...This is there product.
faruk_prlk wrote:
They said that wan ip cannot be written into the dmz of the modem, so I am asking for help. - faruk_prlkNov 15, 2022GuideI entered from the phone, the place to share the screenshot does not work, I will try to log in on the computer tomorrow morning and take a screenshot on my laptop
- faruk_prlkNov 15, 2022GuideI told them I just need to write wan ip in dmz and they said we don't have such a setting.
- Netduma-FraserNov 15, 2022NetDuma PartnerIf it really doesn't have that option there will likely alternative methods we can use once we can see the interface
Only item I saw on there support page was this:
Not sure if this will work or not. The mfr makes this hard to connect other items up seems like. They only want you using there stuff. DMZ or bridge mode is needed here if your going to use the XR router.
Can you ask your ISP if they have a modem only unit without a built in router and wifi available to use?
faruk_prlk wrote:
I told them I just need to write wan ip in dmz and they said we don't have such a setting. - faruk_prlkNov 16, 2022Guide
- Netduma-LiamNov 16, 2022NetDuma Partner
What options do you have in the firewall/forwarding pages there? Can you send screenshots of those?
OK, are there any settings pertaining to modem mode or bridge mode that you can find?
I couldn't find anything about bridging mode, could it have another name?
- FURRYe38Nov 16, 2022Guru - Experienced User
Your last picture has it. "Change Operating Mode"
What do you see when you select this button?
Well that's a shame no Bridge mode.
I would ask the ISP if they have methods to bridge this modem, or if they have a non router modem unit, something modem only with out a built in router. This current model modem will be problematic if you intend to use the XR router.
- faruk_prlkNov 16, 2022GuideMy current keenetic omni is a modem/router. In order to use the netgear xr500 device, do I need to use only a modem? I want to ask one more thing, what do you mean by bridging mode? can it have another name?
