faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
faruk_prlk
Nov 15, 2022Guide
I will enter the modem and share the screen, so we come to a conclusion
faruk_prlk
Nov 15, 2022Guide
Keenetic company does not share any information about the xr500. I will share the screen, please can you describe it?
- FURRYe38Nov 15, 2022Guru - Experienced User
Its recommended to ask the mfr of the modem for help and information regarding there product. Not the NG router.
- faruk_prlkNov 15, 2022GuideThey said that wan ip cannot be written into the dmz of the modem, so I am asking for help.
- Netduma-FraserNov 15, 2022NetDuma PartnerAre you able to access the modem interface? If so please take a screenshot of what you see
Did you ask them what is suppose to be input into the modem?
The Mfr should know how to set this up on there modem...This is there product.
faruk_prlk wrote:
They said that wan ip cannot be written into the dmz of the modem, so I am asking for help. - faruk_prlkNov 15, 2022GuideI entered from the phone, the place to share the screenshot does not work, I will try to log in on the computer tomorrow morning and take a screenshot on my laptop
- faruk_prlkNov 15, 2022GuideI told them I just need to write wan ip in dmz and they said we don't have such a setting.
- Netduma-FraserNov 15, 2022NetDuma PartnerIf it really doesn't have that option there will likely alternative methods we can use once we can see the interface
Only item I saw on there support page was this:
Not sure if this will work or not. The mfr makes this hard to connect other items up seems like. They only want you using there stuff. DMZ or bridge mode is needed here if your going to use the XR router.
Can you ask your ISP if they have a modem only unit without a built in router and wifi available to use?
faruk_prlk wrote:
I told them I just need to write wan ip in dmz and they said we don't have such a setting. - faruk_prlkNov 16, 2022Guide
- Netduma-LiamNov 16, 2022NetDuma Partner
What options do you have in the firewall/forwarding pages there? Can you send screenshots of those?
OK, are there any settings pertaining to modem mode or bridge mode that you can find?
I couldn't find anything about bridging mode, could it have another name?
- FURRYe38Nov 16, 2022Guru - Experienced User
Your last picture has it. "Change Operating Mode"
What do you see when you select this button?
Well that's a shame no Bridge mode.
I would ask the ISP if they have methods to bridge this modem, or if they have a non router modem unit, something modem only with out a built in router. This current model modem will be problematic if you intend to use the XR router.
- faruk_prlkNov 16, 2022GuideMy current keenetic omni is a modem/router. In order to use the netgear xr500 device, do I need to use only a modem? I want to ask one more thing, what do you mean by bridging mode? can it have another name?
- Netduma-LiamNov 17, 2022NetDuma Partner
It would best best to have a modem or a modem/router that can run in a modem/bridge mode or have DMZ functionality. This prevents NAT issues.
Simply put, bridge/modem mode essentially just tells the router to run as a modem. This means the routing side of things is disabled.
- FURRYe38Nov 17, 2022Guru - Experienced User
faruk_prlk wrote:
My current keenetic omni is a modem/router. In order to use the netgear xr500 device, do I need to use only a modem? <Yes, a modem ONLY unit would be recommended and preferred to use with the XR router. Why you should ask your ISP if they have such a option for you to use.
I want to ask one more thing, what do you mean by bridging mode? can it have another name? <I've seen TRANSPARENCY mode used back in history as a term for bridging or putting a modem router combo unit into modem only mode. - faruk_prlkNov 17, 2022GuideI found a vdsl modem from a friend of mine, tp link brand, I will buy it as soon as possible and I will inform you
- faruk_prlkNov 21, 2022GuideHello, a new modem has arrived, I have installed it, what should I do now?
