faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
faruk_prlk
Nov 15, 2022Guide
I told them I just need to write wan ip in dmz and they said we don't have such a setting.
Netduma-Fraser
Nov 15, 2022NetDuma Partner
If it really doesn't have that option there will likely alternative methods we can use once we can see the interface
- faruk_prlkNov 16, 2022Guide
- Netduma-LiamNov 16, 2022NetDuma Partner
What options do you have in the firewall/forwarding pages there? Can you send screenshots of those?
OK, are there any settings pertaining to modem mode or bridge mode that you can find?
I couldn't find anything about bridging mode, could it have another name?
- FURRYe38Nov 16, 2022Guru - Experienced User
Your last picture has it. "Change Operating Mode"
What do you see when you select this button?
Well that's a shame no Bridge mode.
I would ask the ISP if they have methods to bridge this modem, or if they have a non router modem unit, something modem only with out a built in router. This current model modem will be problematic if you intend to use the XR router.
- faruk_prlkNov 16, 2022GuideMy current keenetic omni is a modem/router. In order to use the netgear xr500 device, do I need to use only a modem? I want to ask one more thing, what do you mean by bridging mode? can it have another name?
- Netduma-LiamNov 17, 2022NetDuma Partner
It would best best to have a modem or a modem/router that can run in a modem/bridge mode or have DMZ functionality. This prevents NAT issues.
Simply put, bridge/modem mode essentially just tells the router to run as a modem. This means the routing side of things is disabled.
- FURRYe38Nov 17, 2022Guru - Experienced User
faruk_prlk wrote:
My current keenetic omni is a modem/router. In order to use the netgear xr500 device, do I need to use only a modem? <Yes, a modem ONLY unit would be recommended and preferred to use with the XR router. Why you should ask your ISP if they have such a option for you to use.
I want to ask one more thing, what do you mean by bridging mode? can it have another name? <I've seen TRANSPARENCY mode used back in history as a term for bridging or putting a modem router combo unit into modem only mode. - faruk_prlkNov 17, 2022GuideI found a vdsl modem from a friend of mine, tp link brand, I will buy it as soon as possible and I will inform you
- faruk_prlkNov 21, 2022GuideHello, a new modem has arrived, I have installed it, what should I do now?
- FURRYe38Nov 21, 2022Guru - Experienced User
Set up the XR router with the new modem?
Might factory reset the XR and walk thru the setup wizard and complete it.
- faruk_prlkNov 21, 2022GuideYes, I installed it with the new modem, but when I go to the Xbox network connection settings, I still get the upnp error.
- Netduma-FraserNov 21, 2022NetDuma PartnerIs it a pure modem as in it doesn't have WiFi?
- faruk_prlkNov 21, 2022Guidewifi is working. What settings should I do on the new modem? I keep getting upnp error
- Netduma-FraserNov 21, 2022NetDuma PartnerYou'll need to put it in passthrough mode or put the XR WAN IP in its DMZ
i write this in dmz
- Netduma-FraserNov 21, 2022NetDuma PartnerThat's correct, do you have UPnP disabled on the XR or using port forwarding?
