faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
faruk_prlk
Nov 21, 2022Guide
Yes, I installed it with the new modem, but when I go to the Xbox network connection settings, I still get the upnp error.
Netduma-Fraser
Nov 21, 2022NetDuma Partner
Is it a pure modem as in it doesn't have WiFi?
- faruk_prlkNov 21, 2022Guidewifi is working. What settings should I do on the new modem? I keep getting upnp error
- Netduma-FraserNov 21, 2022NetDuma PartnerYou'll need to put it in passthrough mode or put the XR WAN IP in its DMZ
i write this in dmz
- Netduma-FraserNov 21, 2022NetDuma PartnerThat's correct, do you have UPnP disabled on the XR or using port forwarding?
Upnp is on. I haven't made any other settings on my xr device, what settings should I do?
- Netduma-FraserNov 21, 2022NetDuma PartnerSwitch NAT to Open in WAN Settings, does that resolve the error?
