faruk_prlk
Nov 08, 2022Guide
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
Netduma-Fraser
Nov 21, 2022NetDuma Partner
Did switching the NAT to open work?
faruk_prlk
Nov 21, 2022Guide
I'm getting an error on Xbox when Nat is on, so I turned it off.
- faruk_prlkNov 21, 2022GuideIt's fixed now, no problem
- faruk_prlkNov 21, 2022GuideThere is something I really want to ask, can you show what internet settings you have done on the xr device?
- Netduma-FraserNov 21, 2022NetDuma PartnerFor internet settings you don't really need to change anything else, it won't have an impact for you in game
- FURRYe38Nov 22, 2022Guru - Experienced User
You can check this thread of some settings I use for my XR router:
