roos5
Jan 05, 2022Guide
Upnp Glitched?
Hello, My Upnp has been acting very weird lately, I've been using my XR1000 with my Xbox Series X for a while with no problem at all. Recently i got my PS5 and while i was using it via Ethernet cab...
roos5
Jan 05, 2022Guide
Thanks for the quick answer, My Xbox is showing Open NAT, PS5 NAT type 2 ( moderate). I manually changed the ip of my ps5 to see if the Upnp releases the port 3074 that was being used by the old ps5 address, but it still there in the upnp port table map being used by my ps5 old ip ( which is not assigned to another device).
I remembered that 2 days ago I was getting high packet loss after deactivating the smart connect option, I had to reset the router, ISP too, several times until it got fixed.
Netduma-Fraser
Jan 06, 2022NetDuma Partner
NAT Type 2 is open, it just means you're behind a router. Change the NAT option I mentioned, you won't have any port issues and can ignore the UPnP table.
- GKUK21Jan 09, 2022Aspirant
Won't setting your NAT to open on your router mean you are unsecure and vulnerable?
- Netduma-FraserJan 09, 2022NetDuma PartnerGKUK21 the firewall is still active when set to Open, it's just not as strict as secured but you'll still be protected.
