xIndicaxHigh
Dec 20, 2021Follower
UPnP is Broken on XR1000
I have the Netgear Nighthawk XR1000 an UPnP is broken an won't toggle on. It just keeps unchecking itself on the router.
Im using a CM1200 Cable Modem paired with the XR1000 Pro Gaming Router. Also the ping assist is not working correctly with call of duty cold war. I have strict mode on an fast search turned off an it keeps putting me in lobbies that are 70-100+ MS.
1 Reply
- Netduma-LiamNetDuma Partner
NETGEAR are aware that there's an issue with UPNP on the latest XR1000 firmware and that will be fixed for the next firmware, thanks for raising it though!
What value is your ping assist currently set to?
