Gunny6996
Mar 22, 2023Follower
Upnp issue
I’m on firmware 58 and my upnp being on is a real pain in the neck I can’t figure out how to turn it off I’m not sure if updating to the latest will fix the issue and I also can’t afford it to change ...
Netduma-Fraser
Mar 23, 2023NetDuma Partner
What's the issue you're having exactly with it not turning off? On the UPnP page there is an option to disable it.
