jmychiox
Oct 03, 2021Tutor
UPnP on XR1000 not working after firmware update
Recently purchased an XR1000 and the UPnP feature will not stay checked. I don't believe this is artifactual as the devices connected are having UPnP issues. I'm seeing another user has run into th...
Netduma-Liam
Oct 04, 2021NetDuma Partner
Sorry to hear this!
As you might've read, Netgear are aware of this problem and will have it resolved for the next firmware update.
What's the exact make and model of your modem/router? The best solution would probably be to put the XR1000 in the DMZ of that router if possible.
- jmychioxOct 04, 2021Tutor
Thanks for getting back to me. It's a BGW320 running passthrough to the XR1000.
- Netduma-LiamOct 04, 2021NetDuma Partner
OK thanks, are you able to take it out of passthrough and instead put the XR1000 WAN IP in the DMZ of the BGW320? After this, reboot the XR1000 and that will work just fine until UPnP is working again on the XR1000?
- jmychioxOct 05, 2021Tutor
I'm not. Is there an alternative solution? Also, how soon should we expect this to be updated on the XR1000?
