jmychiox
Oct 03, 2021Tutor
UPnP on XR1000 not working after firmware update
Recently purchased an XR1000 and the UPnP feature will not stay checked. I don't believe this is artifactual as the devices connected are having UPnP issues. I'm seeing another user has run into th...
jmychiox
Oct 04, 2021Tutor
Thanks for getting back to me. It's a BGW320 running passthrough to the XR1000.
Netduma-Liam
Oct 04, 2021NetDuma Partner
OK thanks, are you able to take it out of passthrough and instead put the XR1000 WAN IP in the DMZ of the BGW320? After this, reboot the XR1000 and that will work just fine until UPnP is working again on the XR1000?
- jmychioxOct 05, 2021Tutor
I'm not. Is there an alternative solution? Also, how soon should we expect this to be updated on the XR1000?
- Netduma-FraserOct 05, 2021NetDuma PartnerYou can leave in passthrough mode that's fine. UPnP should be enabled by default - it can be difficult to get an Open NAT on many consoles simultaneously even using UPnP. Easiest option would be to switch NAT to Open in WAN Settings and that should resolve it
- PiRolasOct 14, 2021Aspirant
Tengo el mismo problema en mi XR1000.
Experimento un juego online lento. La PlayStation 5 da problema de Nat al estar conectada a XR1000 y jugar online es una pesadilam todo el juego lento . Me da problemas con el UPnP y Nat.
¿Cuándo se va a solucionar esto? Nos gastamos mucho dinero (355 € en mi caso) en un router que no cumple con sus funciones.
Por favor, una solución YA.
Gracias (llevamos mucho tiempo esperando)
