jmychiox
Oct 03, 2021Tutor
UPnP on XR1000 not working after firmware update
Recently purchased an XR1000 and the UPnP feature will not stay checked. I don't believe this is artifactual as the devices connected are having UPnP issues. I'm seeing another user has run into th...
Sheldonng
Nov 27, 2021Aspirant
some here.
xr1000 upnp still not work, it's netgear Give up on the xr1000 update?
- Netduma-FraserNov 27, 2021NetDuma PartnerThey haven't given up don't worry, UPnP is still working in the background, they'll get it resolved
- fewjrDec 13, 2021Aspirant
Just bought XR1000 last week. I noticed that I hadn't checked the box for upnp and when I did, it broke my open NAT to XboxLive. I am running the newest firmware update. I see after reading a couple of post on here about this that it has been going on for a while. Now we are in the middle of December. XR1000 was released last September wasn't it? Hopefully this will be resolved soon. I am in the same boat as the rest, being that when I check the upnp box and apply, the check goes away. The first time I did it I got port 3075 instead of 3074 to the Xbox Series X. The second time no ports and the check box never stayed checked. The NAT was opened before I fiddled with setting upnp, so I think it was set by default as was stated in another post. Now I'm moderate, so I guess I'll do a factory reset.
edit...September 2020....my bad.
