jmychiox
Oct 03, 2021Tutor
UPnP on XR1000 not working after firmware update
Recently purchased an XR1000 and the UPnP feature will not stay checked. I don't believe this is artifactual as the devices connected are having UPnP issues. I'm seeing another user has run into th...
Netduma-Liam
Dec 14, 2021NetDuma Partner
Netgear are well aware of this issue and it will be fixed for the next firmware update. In the mean time, you could put the XR1000 in the DMZ of the Comcast/Xfinity modem. That would resolve any NAT issues you could be having.
fewjr
Dec 14, 2021Aspirant
Hello,
The modem is a Technicolor CGM4331COM. I did a factory reset this morning and setup from scratch. I didn't touch upnp as that's where I messed up to start with. I believe like I've read elsewhere on here that it is in upnp by default but it just doesn't show it. I'm back to an open Nat with ipv6 and all on the Xbox. One thing I've noticed in the device manager. In the tree mode the 2.4 wireless is labeled but the 5gh is not. Curious.... Nothing to do with this post though. Thanks for the help.
- Netduma-FraserDec 14, 2021NetDuma PartnerIf you make a new topic on that we can take a look!
- fewjrDec 15, 2021Aspirant
The 5gh wireless was showing in the tree when I got home...strange. This morning however I am back to a moderate NAT on both Xboxes. I'm not sure whats causing these issues. I haven't made any changes in UPnP, port forwarding, DMZ at all. I was playing around with the Geo Filter last night but that was all. Any ideas? I was thinking of port forwarding but I'm not sure what's going on with UPnP. I don't want both going at the same time as thats not advised.
- Netduma-FraserDec 15, 2021NetDuma PartnerSet NAT to Open in WAN Settings and that should get you an Open NAT very easily
