jmychiox
Oct 03, 2021Tutor
UPnP on XR1000 not working after firmware update
Recently purchased an XR1000 and the UPnP feature will not stay checked. I don't believe this is artifactual as the devices connected are having UPnP issues. I'm seeing another user has run into th...
Netduma-Fraser
Oct 15, 2021NetDuma Partner
Appears to be cosmetic and is actually still enabled, you can ignore it
JinLee
Feb 14, 2022Aspirant
Where can I go to check if mine's enabled? Just asking as I'm having the same issue.
- Netduma-LiamFeb 15, 2022NetDuma Partner
You can find this info in the below guide:
https://kb.netgear.com/24306/How-do-I-enable-Universal-Plug-and-Play-on-my-Nighthawk-router
- JinLeeFeb 15, 2022Aspirant
well, the nighthawk app for xr1000 doesn't provide the option to see, so that's a no go.
and the web browser's page is where the issue occurred; the checkbox keeps unchecking itself upon clicking apply.
Correct, it's a known issue, as long as you're not having any issues with NAT then UPnP should still be working.
- JesusI_Mar 24, 2022AspirantWhats going on with the XR1000 it keeps saying Rapp not loading over and over I can’t see the Geo filter and QoS settings???
- FURRYe38Mar 24, 2022Guru - Experienced User
What browser are you using?
What FW is currently loaded?
