roos5
Feb 24, 2021Guide
UPnP Portmap Table empty/blank
Hello team, I recently joined the Netgear family and im very happy with my XR500. i've been using it since last week and still cant find the way to add my PS4 pro to the Upnp list, i need assiatn...
- Feb 24, 2021Okay that will be absolutely fine, it is just an aesthetic issue but I have raised it with NG and they will look into it.
roos5
Feb 24, 2021Guide
Hello Netduma-Faser,
Thank you so much for the quick answer, I do have a NAT type 2, im using the firmware version V2.3.2.114.
Netduma-Fraser
Feb 24, 2021NetDuma Partner
- roos5Feb 24, 2021Guide
Understood, thank your for the assiatnce.
