catan92
Oct 24, 2019Aspirant
Use 10Gb port for LAN Nighthawk
Is it possible to use the 10Gb LAN SFP port as LAN w/o internet?
Oct 24, 2019Guru - Experienced User
Check the usual manual for official uses for that port.
- Netduma-FraserOct 24, 2019NetDuma PartnerAre you wanting to use the router as a LAN switch or just have that specific port without internet and just for LAN?
- catan92Oct 24, 2019AspirantJust that specific port for LAN
- Netduma-FraserOct 24, 2019NetDuma PartnerNo I don't think that would be possible. A workaround could be blocking whatever the device connected to that port is via the Device Manager.
