tanjaawi
Apr 14, 2021Tutor
Using Geo-filter on PS4 with xr500 nighthawk
Hi there, I wanted to ask this question to netgear but my warranty finished a month ago. Currently i am playing call of duty warzone on a ps4. I bought the xr500 to be able to geo filter selected...
Netduma-Fraser
Apr 14, 2021NetDuma Partner
The in game location will not change as you're not using a VPN and is not required to force other servers.
The Spanish server is not always online, that is Activisions choice. Can you provide a screenshot of your Geo-Filter settings please?
tanjaawi
Apr 14, 2021Tutor
Hi there!
i am using VPN, i have nord vpn on my laptop and phone and the location is set to spain.
- Netduma-FraserApr 14, 2021NetDuma PartnerYou'll need to look at why that VPN isn't changing the location then if you're not using it on Hybrid VPN. Turn Ping Assist to 0 as that is how the server outside connected. The server with a solid while circle is required for online play, you can ignore that.
- tanjaawiApr 14, 2021Tutor
I do not understand what you mean by hybrid vpn, my laptop and phone have the nordvpn app so i can connect to vpn but my playstation doesnt. if i click on hybrid vpn on the router it only gives two providers, "hidemyass" and "purevpn". I'll upload a screentshot.
ping has been set to 0.
- Netduma-LiamApr 15, 2021NetDuma Partner
So what you'll need to do is use the 'Advanced' setup option, the below guide details how you can do this:
