ArtVanderlay
Jul 11, 2021Aspirant
Using Hybrid VPN with Torguard
I'm attempting to use Torguard with my Netgear Nighthawk XR500 Router. I'm requesting details for what type of config dumaOS needs. I'm running Firmware version CR500 V2.3.2.114 When creating...
Netduma-Liam
Jul 13, 2021NetDuma Partner
Thanks for posting!
Could you also send over the Open VPN file that's generated with this configuration? I'm entirely sure if it will work with multiple VPN servers selected, could you see if you have more success just selecting one when generating the configuration file?
- ArtVanderlayJul 13, 2021Aspirant
It's as if it has a difficult time resolving us.atl.torguard.com:1912
client
dev tun
proto udp
remote us-atl.torguard.com 1912
remote-cert-tls server
auth SHA256
key-direction 1
setenv CLIENT_CERT 0
<tls-auth>
-----BEGIN OpenVPN Static key V1-----
770e8de5fc56e0248cc7b5aab56be80d
0e19cbf003c1b3ed68efbaf08613c3a1
a019dac6a4b84f13a6198f73229ffc21
fa512394e288f82aa2cf0180f01fb3eb
1a71e00a077a20f6d7a83633f5b4f47f
27e30617eaf8485dd8c722a8606d56b3
c183f65da5d3c9001a8cbdb96c793d93
6251098b24fe52a6dd2472e98cfccbc4
66e63520d63ade7a0eacc36208c3142a
1068236a52142fbb7b3ed83d785e12a2
8261bccfb3bcb62a8d2f6d18f5df5f36
52e59c5627d8d9c8f7877c4d7b08e19a
5c363556ba68d392be78b75152dd55ba
0f74d45089e84f77f4492d886524ea6c
82b9f4dd83d46528d4f5c3b51cfeaf28
38d938bd0597c426b0e440434f2c451f
-----END OpenVPN Static key V1-----
</tls-auth>
resolv-retry infinite
nobind
cipher AES-128-CBC
auth-user-pass
compress
ncp-disable
tun-mtu-extra 32
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>- Netduma-FraserJul 13, 2021NetDuma PartnerCould you make a config for OpenVPN version 2.3.4 and then see if it works, if not post that please and hopefully with a few edits we can get it working
- ArtVanderlayJul 14, 2021Aspirant
I created the config using OpenVPN 2.3
I attached a copy of the Torguard config generator settings I used.
Here is a copy of the error log:
Wed Jul 14 18:27:36 2021 RESOLVE: Cannot resolve host address: us-atl.torguard.com:1912 (Name or service not known)
Wed Jul 14 18:27:36 2021 Could not determine IPv4/IPv6 protocol Wed Jul 14 18:27:36 2021 SIGUSR1[soft,init_instance] received, process restarting
Wed Jul 14 18:27:36 2021 Restart pause, 40 second(s) Wed Jul 14 18:28:16 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Here's a copy of the config:
client
dev tun
proto udp
auth SHA256
key-direction 1
<tls-auth>
</tls-auth>
nobind
cipher AES-128-CBC
auth-user-pass
comp-lzo adaptive
tun-mtu-extra 32
<ca>
E/9Q3h4=
</ca>
