Murllin
Mar 19, 2019Aspirant
Using the Nighthawk XR 500 in AP mode
I recently purchase the nighthawk XR500 router. It seems to have alot of great network performance enhancing features. However, my ISP provides a modem/router combo that is set up to provide wifi to o...
Mar 19, 2019Guru - Experienced User
When in AP mode, ALL router features are disabled on the XR500. Only wireless is left running.
You can do the following:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
- Netduma-FraserMar 19, 2019NetDuma PartnerGreat advise above! What do you mean by two houses? As I would highly suggest you do not have anything connected to the ISP hub otherwise the QoS on the router will not be able to control all devices.
- MurllinMar 19, 2019AspirantThere are 2 houses because my set up is a bit unconventional. The ISP in my area does not service my home. They do service my neighbors home 400 feet in front of me. So Ive made an arrangment with my neighbor to set up and pay for internet service at their house, providing them with free wifi. Then I have an ubiquiti nanobeam installed on our roofs that send the signal to my own home as well. So theres the ISP provided router in their home that is connected via nanobeam to my home and into the XR500.
- MurllinMar 19, 2019AspirantThanks, those are good suggestions. I thought about bridging the connection. However in doing so that would disable the wifi access at the first house. Unfortunatly I have to provide wifi coverage for both homes. Would it be possible to instead, install a modem without router functions at the first home and then attach a switch to the modem. Would I be able to put a seperate wifi router in home #1 and then use my XR500 as a wifi router in home #2?
- FURRYe38Mar 19, 2019Guru - Experienced User
No that is not possible.
Your best solution if you need to supply internet and wifi access with the home #1 would be to use the ISP modem and wifi there, then use its DMZ for the XR router at home #2. You can leave the wifi enabled at the ISP modem in your case since the distance between the modem and XR router are far.
Ok now that you posted distance. If your getting wifi via wifi beam, then I believe this would work with the XR in router mode. However having all this wifi devices and beam in the middle, you may see odd or bad gaming performances in this kind of configuration. Having different methods to get from one point to another while data traverses these could pose a problem.
- Netduma-FraserMar 19, 2019NetDuma PartnerThat's quite a scenario, the above is probably the best method but unfortunately the QoS won't be as effective.
