Murllin
Mar 19, 2019Aspirant
Using the Nighthawk XR 500 in AP mode
I recently purchase the nighthawk XR500 router. It seems to have alot of great network performance enhancing features. However, my ISP provides a modem/router combo that is set up to provide wifi to o...
Mar 19, 2019Guru - Experienced User
When in AP mode, ALL router features are disabled on the XR500. Only wireless is left running.
You can do the following:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Netduma-Fraser
Mar 19, 2019NetDuma Partner
Great advise above! What do you mean by two houses? As I would highly suggest you do not have anything connected to the ISP hub otherwise the QoS on the router will not be able to control all devices.
