Funstuff
Apr 14, 2021Apprentice
Using XR500 and unable to connect to shared PC with file explorer
Hello, I have been working on this for awhile now, I am using the XR500 DumaOS 3.0 beta .120 build but I doubt that is the issue. I am guessing it is a DNS issue somewhere but after searching...
Netduma-Liam
Apr 15, 2021NetDuma Partner
Hey John,
Thanks for all the information! Could you give us a better idea of your environment and where your PC and the remote PC sit in it?
- FunstuffApr 15, 2021Apprentice
Netduma-Liam Sorry, providing more info.
These are two home PCs. Both are running Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2).
Everything is hardwired with cat8 as far as the devices concerned.
The PCs are about 6 ft apart and each are connected to the router with 10ft of cable to the XR500 which is about 2-3 feet from each PC.
The modem is right next to the XR500
Router modifications:
Changed router IP
Added both PCs to the address reservation table due to suggestion from beta test and the device manager on the router.
Windows defender firewall
Bitdefender
No VPN
Modem: MB8600
Router XR500 is running DumaOS V2.3.2.120
PCs: Asus G11CD
Digital Storm semi-self picked build
68-72 degrees, no precipitation, just kidding
Not sure what all you are looking for, just let me know if you need more.
John
- FunstuffApr 20, 2021Apprentice
Netduma-Liam Oh my, I am soooo sorryy, I responded to this a while back but it must not have gotten sent or something. Anyway I'll retype.
Ok they are 2 machines running: Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2)
Asus G11CD
Digital Storm build
Modem: Motorola MB8600
Router XR500 build v2.3.2.120 beta
Everything is hardwired, cat8
The PCs are approximately 6 feet apart and the modem and router are on a table in between about 2-3 feet from either PC.
Changes to router are:
IP of router
Both PCs are set in the IP reservation table due to previous test for device manager issues on the router
DNS servers set to cloudflare and Cisco
QOS disabled per suggestion for the e-mail logs crap I have been messing with.
IPV6 enabled with auto detect
I think that is it, holler if you need more.
Thanks,
John
Netduma-Liam My reponses are not getting posted, trying a 3rd time. I am sooooo sorry I thought I replied to this several days ago.
PCs:
G11CD
Digital Storm build
Both running Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2)
Router: XR500 v2.3.2.120 beta
Cables: cat8
The 2 PCs are about 6 feet apart and the modem and router are on a table about 2-3 feet away from the PCs. Everything is hardwired pertaining to this scenario. There are wireless things but not involved.
Router changes
IP of router
both PCs are in the IP reservation table for another test of the router device manager
QOS disabled per suggestion from messing with the router e-mailing logs I have been messing with
IPV6 enable auto detect
DNS set to Cloudflare and Cisco
Thanks,
John
