Funstuff
Apr 14, 2021Apprentice
Using XR500 and unable to connect to shared PC with file explorer
Hello, I have been working on this for awhile now, I am using the XR500 DumaOS 3.0 beta .120 build but I doubt that is the issue. I am guessing it is a DNS issue somewhere but after searching...
Netduma-Liam
Apr 15, 2021NetDuma Partner
Hey John,
Thanks for all the information! Could you give us a better idea of your environment and where your PC and the remote PC sit in it?
Funstuff
Apr 15, 2021Apprentice
Netduma-Liam Sorry, providing more info.
These are two home PCs. Both are running Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2).
Everything is hardwired with cat8 as far as the devices concerned.
The PCs are about 6 ft apart and each are connected to the router with 10ft of cable to the XR500 which is about 2-3 feet from each PC.
The modem is right next to the XR500
Router modifications:
Changed router IP
Added both PCs to the address reservation table due to suggestion from beta test and the device manager on the router.
Windows defender firewall
Bitdefender
No VPN
Modem: MB8600
Router XR500 is running DumaOS V2.3.2.120
PCs: Asus G11CD
Digital Storm semi-self picked build
68-72 degrees, no precipitation, just kidding
Not sure what all you are looking for, just let me know if you need more.
John
