Funstuff
Apr 15, 2021Apprentice
Using XR500 and unable to connect to shared PC with file explorer
Hello, I have been working on this for awhile now, I am using the XR500 DumaOS 3.0 beta .120 build but I doubt that is the issue. I am guessing it is a DNS issue somewhere but after searching...
Netduma-Fraser
Apr 23, 2021NetDuma Partner
Yes that could work.
Just to check, have you allowed both PCs to be discoverable on the local network? https://www.windowscentral.com/how-configure-network-discovery-windows-10-0
Funstuff
Apr 24, 2021Apprentice
Netduma-Fraser Looks like my previous posts caught up.
Ok, I hooked up the MR314 and same error, I also completely uninstalled Bitdefender, liking that security program less and less each day. It blocked me from logging into my modem, sheesh. I'l worry about that leater.
Below are screen shots of the network pages for each PC
[img]https://i.imgur.com/XGDTuhm.png[/img]
and
[img]https://i.imgur.com/2zHtX69.png?1[/img]
This is a net share of the remote PC
[img]https://i.imgur.com/HdfVBO7.png?1[/img]
I have FTP set up as I have mentioned
I have printer sharing working
I can remote login several ways
Next image is pings and nslookup from main/host PC
[img]https://i.imgur.com/6sqcgE1.png?1[/img]
- Netduma-FraserApr 24, 2021NetDuma PartnerCould you try disabling IPv6 please and see if it works?
- FunstuffApr 24, 2021Apprentice
Netduma-Fraser and Netduma-Liam
Thank you both for trying to help me with this, I really appreciate it. I have not figured it out but I do believe it is not a router issue, which you two probably knew or guessed already :)
Feel free to close this or whatever you need to do.
John
