Nit3H8wk
Jun 05, 2018Initiate
V2.3.2.18 slow ethernet speed
After updating firmware to 2.3.2.18 I am unable to get more than 200Mb down even after a factory reset with a killer E2400 gigabit ethernet controller and cat6 cables less than 2 weeks old. On my iph...
- Jun 06, 2018
Was not the router. Bypassed directly to modem same speed issue. Shortly after reconnecting the router the speeds are back to normal now.
https://www.speedtest.net/my-result/d/c316d0a4-df51-4f05-b5a6-99d5b86fad19
Netduma_Jack
Jun 05, 2018NetDuma Partner
It would be good to isolate whether it is the firmware or a setting change. So could you downgrade back to a previous version and see if speeds return to normal. Thanks
Nit3H8wk
Jun 06, 2018Initiate
