mebaby333
May 05, 2020Tutor
V2.3.2.26 for XR500 LAN Port disconnect
Can someone please provide the Beta (V2.3.2.26) for the XR500. I had it last week but upgraded to the newest version 2.3.2.56 because it said it fixed the LAN Port disconnect, but alas it doesn't. ...
mebaby333
May 05, 2020Tutor
I did, i reached to Netduma-Fraser and NetDuma-Jack but they are not getting back to me, so i thought i would try to reach out here.
FURRYe38 wrote:I would contact who ever you got the beta from and get it from them again. Be sure to keep the FW files back up so you have them if you need.
May 05, 2020Guru - Experienced User
Hopefully they will respond soon. There in the UK regiona I believe so it's night time there I think. If not, try a NG forum Moderator.
- mebaby333May 05, 2020Tutor
I am hoping, but i private messaged them on Friday of last week and still nothing, and why i posted on here today.
Hoping maybe someone else may have it, that can hook it up. This problem is so annoying and not sure why they have not fixed yet.
Something in that BETA version prevents it from happening so not sure why they have not fixed yet.
- Netduma-FraserMay 05, 2020NetDuma PartnerLooking back in PMs I sent you the .32 version which has since been made available publicly here: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
yeah that version doesn't work.. LAN Ports still disconnect.. The only one that worked was .26. Is there anyway to get that one back?
