CptinCaveme
Feb 08, 2018Tutor
Verizon Fios gigabit slow speeds
Slow download speeds with verizon fios gigabit service.
itsyamce
Feb 22, 2018Guide
Maybe it’s the nighthawk router:(
- Netduma-FraserFeb 22, 2018NetDuma PartnerIf that's the case then it is very likely due to the MAC address or DNS. Set the MAC address of the XR500 to the previous router's MAC address. As well as finding the DNS for your ISP and state and entering that into the XR500.
Also make sure the ethernet cable you're using is Cat5e and above, as well as the PC you're using to test that it's network adapter can handle your speeds.
If you're still having issues with speed please download & install TeamViewer https://www.teamviewer.com/en/download/windows/ and then PM me with the ID and password it shows and then I can take a look at what is happening. - CptinCavemeFeb 22, 2018Tutor
Should I try the MAC address for my setup? As I would have two devices with the same MAC connected to the ONT.
- Netduma-FraserFeb 22, 2018NetDuma PartnerTo clarify your setup is ONT > Fios router (required for TV services) and then the XR500 plugged into the Fios router? In that case you shouldn't need to do that I don't think. If you want to do TeamViewer I am happy to take a look now.
Yes that is my setup. I am at work at the moment. I know you are UK time zone (5 hours ahead) I get off at 7pm eastern 12 your time.
Can I get back to you on my availability.
- Netduma-FraserFeb 22, 2018NetDuma PartnerYes absolutely, I am available anytime between midday to 2am UK time Sunday - Friday.
- itsyamceFeb 22, 2018Guide
Hey are you availabe ?
- Netduma-FraserFeb 22, 2018NetDuma PartnerHello, yes if you can PM me your TeamViewer details now I can take a look.
do i need to put my broadband MAC Address from Fios to Netgear router ?
- Netduma-FraserFeb 22, 2018NetDuma PartnerIf you haven't followed the suggestions I've given yet I would do so first to see if that resolves your issue yes.
ok i will
im going to download team viewer
how do i run teamviewer"??
- Netduma-FraserFeb 22, 2018NetDuma PartnerOnce installed open up the application and PM me the ID & password it gives you please.
- itsyamceFeb 23, 2018Guide
hi fraser are you aviable ?
- Netduma-FraserFeb 23, 2018NetDuma PartnerFirst lets establish what you are supposed to get. With your PC wired to the ONT what speeds do you get on speedtest.net?
ok i will test right now
im getting around 84down 101upload
thats connected to my ONT my modem
- Netduma-FraserFeb 23, 2018NetDuma PartnerIf that's what you're getting then it is not a router issue, it's either a fault with the ONT or something on your ISPs line.
i would hope not the new router caused it but do i need to contact fios?
- Netduma-FraserFeb 23, 2018NetDuma PartnerNo router would cause that. Yes I would recommend doing so as your speeds seem to fluctuate wildly directly connected to the ONT.
ok i will do so
- itsyamceFeb 23, 2018GuideBut i still recieve low mbps on my xbox one with fios quantuam & netgear
