CptinCaveme
Feb 08, 2018Tutor
Verizon Fios gigabit slow speeds
Slow download speeds with verizon fios gigabit service.
CptinCaveme
Feb 22, 2018Tutor
Should I try the MAC address for my setup? As I would have two devices with the same MAC connected to the ONT.
Netduma-Fraser
Feb 22, 2018NetDuma Partner
To clarify your setup is ONT > Fios router (required for TV services) and then the XR500 plugged into the Fios router? In that case you shouldn't need to do that I don't think. If you want to do TeamViewer I am happy to take a look now.
- CptinCavemeFeb 22, 2018Tutor
Yes that is my setup. I am at work at the moment. I know you are UK time zone (5 hours ahead) I get off at 7pm eastern 12 your time.
Can I get back to you on my availability.
- Netduma-FraserFeb 22, 2018NetDuma PartnerYes absolutely, I am available anytime between midday to 2am UK time Sunday - Friday.
- itsyamceFeb 22, 2018Guide
Hey are you availabe ?
- Netduma-FraserFeb 22, 2018NetDuma PartnerHello, yes if you can PM me your TeamViewer details now I can take a look.
