CptinCaveme
Feb 09, 2018Tutor
Verizon Fios gigabit slow speeds
Slow download speeds with verizon fios gigabit service.
Netduma-Fraser
Feb 23, 2018NetDuma Partner
Once installed open up the application and PM me the ID & password it gives you please.
itsyamce
Feb 23, 2018Guide
hi fraser are you aviable ?
- Netduma-FraserFeb 23, 2018NetDuma PartnerFirst lets establish what you are supposed to get. With your PC wired to the ONT what speeds do you get on speedtest.net?
- itsyamceFeb 23, 2018Guide
ok i will test right now
im getting around 84down 101upload
thats connected to my ONT my modem
- Netduma-FraserFeb 23, 2018NetDuma PartnerIf that's what you're getting then it is not a router issue, it's either a fault with the ONT or something on your ISPs line.
i would hope not the new router caused it but do i need to contact fios?
- Netduma-FraserFeb 23, 2018NetDuma PartnerNo router would cause that. Yes I would recommend doing so as your speeds seem to fluctuate wildly directly connected to the ONT.
ok i will do so
