CptinCaveme
Feb 08, 2018Tutor
Verizon Fios gigabit slow speeds
Slow download speeds with verizon fios gigabit service.
Netduma-Fraser
Feb 23, 2018NetDuma Partner
First lets establish what you are supposed to get. With your PC wired to the ONT what speeds do you get on speedtest.net?
itsyamce
Feb 23, 2018Guide
ok i will test right now
- itsyamceFeb 23, 2018Guide
im getting around 84down 101upload
thats connected to my ONT my modem
- Netduma-FraserFeb 23, 2018NetDuma PartnerIf that's what you're getting then it is not a router issue, it's either a fault with the ONT or something on your ISPs line.
i would hope not the new router caused it but do i need to contact fios?
- Netduma-FraserFeb 23, 2018NetDuma PartnerNo router would cause that. Yes I would recommend doing so as your speeds seem to fluctuate wildly directly connected to the ONT.
ok i will do so
