AllanAyala
Aug 12, 2020Tutor
Verizon Fios issues!! Please help!
Hello all. I’ve been having a problem over the past few months and I’m at my end. I purchased the XR450 during Christmas 2019 and at that time I called Fios support and had them assist with removing ...
Netduma-Fraser
Aug 13, 2020NetDuma Partner
It sounds like your public IP is renewing every 7 days, do you have a dynamic or static IP? Find out what the MAC address of the gateway is and then in Internet setup on the XR change the MAC address to that instead. Then plug it directly into the ONT, does that resolve the issue?
