Akuma_Inu
Aug 02, 2018Tutor
Very Disappointed with XR500
Purchased a XR500 a couple days ago to upgrade an older R7000, really had high hopes for the router, but to my dismay it looks like I will be returning it. Setup went smooth, it was after the set up...
Netduma-Fraser
Aug 02, 2018NetDuma Partner
Have you contacted Netgear support about this? I surmise you would probably have a better experience by disabling Smart Connect and having the individual bands to connect to and use a WiFi analyser to select the least congested channel
