Akuma_Inu
Aug 02, 2018Tutor
Very Disappointed with XR500
Purchased a XR500 a couple days ago to upgrade an older R7000, really had high hopes for the router, but to my dismay it looks like I will be returning it. Setup went smooth, it was after the set up...
Aug 02, 2018Guru - Experienced User
Let us now the results when you can.
Akuma_Inu
Aug 03, 2018Tutor
Sorry for the delay in the update, did not have time to work on it last night, and have been at work all day today. So I went back and did a factory reset again, went through the set up process and now it seems everything is working, with the exception of our phones, both phones are Samsung S8's. They will connect to the WiFi, but says "internet may not be available". I know that the internet is available because I am typing this message over WiFi on my laptop. I have sent in a support request email, so I guess it's a waiting game now to see what they say. I did try to turn off Smart Connect and also tried different channels, as suggested, neither worked.
- Netduma_JackAug 04, 2018NetDuma Partner
Thanks for the update. Hopefully support assists. One thing that might be worth trying is going into each phone's WiFi settings and scan for available routers (SSiDs). Under the XR500 - click on it and tell it to Forget the Device. In other words, clear any memory of the router from your phone's memory.
Then try to connect to it fresh again and re-enter the password etc. I've had issues before where my phone gets confused and this has fixed it.
- Akuma_InuAug 05, 2018Tutor
So after being on the phone for almost 2 hours with tech support, doing everything I already tried over again, Netgear is going to RMA my router. They think it could be a hardware problem. So now I wait and see if the new router does the same thing.
- Netduma-FraserAug 06, 2018NetDuma PartnerThanks for the update, let us know if the new unit resolves your issue.
