Hapapaya
Jul 09, 2022Follower
Very frustrated.
I had an issue with my XR500 randomly shutting off multiple times a day. I opened a hardware support case because my technical support had expired. I failed to reply in time because for about a coupl...
Netduma-Fraser
Jul 10, 2022NetDuma Partner
DarrenM @ would you be able to help with this please?
I would recommend plugging the router directly into a wall outlet and if it still continues trying a different power adapter, if it's actually turning off then it could be a power issue.
