Porter5345
Jun 11, 2020Follower
Very slow internet speeds
Hi all, I am having a lot of trouble getting this router to work properly. My expected speeds are at least 900 down and 900 up. As I have connected the nighthawk to the fios G1100 router (wh...
Jun 11, 2020Guru - Experienced User
A couple things you can try. But to start off with the G1100 also has routing over coax for its set top boxes so I'm not sure how fully function its bridge/modem only mode works.
1. Try putting it back in router mode and disable its wifi. Then put the ip address for the XR300 int the G1100's dmz.
2. also try manually setting the speed for the qos for the xr300
https://kb.netgear.com/000053112/How-do-I-set-up-QoS-on-my-Nighthawk-Pro-Gaming-Router
I'd read through a few of the posts about the g1100.
https://forums.verizon.com/t5/Fios-Internet/NetGear-Orbi-with-FIOS-g1100/td-p/887973
https://forums.verizon.com/t5/Fios-Internet/Bridge-G1100-So-Your-Router-Becomes-Primary/td-p/861852
- Netduma-FraserJun 11, 2020NetDuma PartnerAs well as the above, double check link speeds in the Device Manager table view are 1000mbps. Also disable QoS in the Anti-Bufferbloat option menu and see what you get.
