PachaTC
Dec 23, 2021Guide
Virgin Media TV home screen not loading thumbnails - Nighthawk XR1000
Hi All I hope someone knowledgable can help!? Yesterday i took the plunge and installed a Nighthawk XR1000, everything seems to have connected to it fine and I am now getting to grips with t...
- Dec 23, 2021It will be using those settings automatically so not need to worry about that. Toggle IGMP Proxying in WAN Settings, then see if it works please
PachaTC
Jan 01, 2022Guide
Netduma-Fraser wrote:
Happy New Year! Interesting, I had the same hub and I found the modem mode to be a bit finicky, put it back into router mode then copy the WAN IP from the XR System Information page and put it in the VM DMZ. Then see if the issue is resolved please.
Thanks Netduma-Fraser
Ive done that and it has worked, hopefully it remains this time! :)
We do sometimes get power cuts here, will this affect what ive just done? i.e. the XR1000 be assigned a different IP address? I notice that the XR1000 has a completely different IP address anyway (on the system information page) once the superhub goes into modem mode.
Thanks again, itll keep the mrs from moaning at me for a bit :D
Netduma-Fraser
Jan 01, 2022NetDuma Partner
Great to hear that! Yes if the power cuts then the XR would be assigned a new address and the DMZ would then not work. The IP you have when it is in modem mode is your public IP vs a local IP assigned when VM is in router mode.
So to combat it changing, take that same IP you put in the DMZ and make it reserved/static on the hub. That way the XR will always have that IP even after reboots/resets and the DMZ will always be valid.
- PachaTCJan 01, 2022Guide
Thanks, ill sort that when the power next cuts
I have a different issue now though..!
I cant access the DumaOS? i get the error -
haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
how do i fix this please?
- Netduma-FraserJan 01, 2022NetDuma PartnerReboot the router using the button, wait 2 minutes then access and it should load correctly.
That worked, but annoyingly restored everything to factory settings :(
Thanks for your help :)
