4Scarrs_Gaming
Sep 03, 2019Aspirant
VLAN tagging on WAN port SFP+
I need to create a VLAN 35 for my ppoe connect to my ISP. However, I do not see for the life of me how I can create a VLAN and tag the WAN port. I am using a SFP+ connection.
Netduma_Alex
Sep 04, 2019NetDuma Partner
Go to Settings > Advanced Settings > VLAN/Bridge Settings > Enable VLAN/Bridge Group > By VLAN Tag Group > Add
Hopefully that's what you're looking for
4Scarrs_Gaming
Sep 04, 2019Aspirant
That will only allow me to tag ports 1-6 and not the wan port. My ISP requires VLAN 35 on the WAN port.
- Netduma-FraserSep 04, 2019NetDuma PartnerIf you edit the internet one there already, it says all wired ports, does that not work at all?
- 4Scarrs_GamingSep 04, 2019Aspirant
I cant see how to edit it and change the VLAN from 10 to 35
- Netduma-FraserSep 04, 2019NetDuma PartnerClick on the circle beside it and then click edit, should be able to change it from there.
