jjdresselhaus
Jan 18, 2021Aspirant
VLAN Tagging Prohibits LAN Communication & SmartConnect Issues
Resurrecting a problem that this post had -- https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-VLAN-tagging-making-wifi-devices-unable-to-communicate/td-p/1842061/page/3 Just bo...
Netduma-Liam
Jan 19, 2021NetDuma Partner
Thanks for posting, sorry to hear you've having issues!
Could you please confirm if you've currently got SmartConnect disabled? If not, could you please do so and just test the wifi devices connectivity?
Could you please also go to Advanced Wi-Fi settings and disable beamforming, MU-MIMO & HT160?
jjdresselhaus
Jan 19, 2021Aspirant
Yes -- SmartConnect is disabled, and I'm currently using two separate SSIDs.
Beamforming, MU-MIMO & HT160 are now all disabled. Is this to fix SmartConnect or the LAN Communication?
- Netduma-FraserJan 19, 2021NetDuma PartnerFor the devices issue, could you make a Guest WiFi network and allow the option to communicate locally, connect them both to that and see if it works then please? For Smart Connect it will only switch to 5GHz if the device needs the extra bandwidth.
- jjdresselhausJan 19, 2021Aspirant
Is Guest-Wifi the only option? That seems counter-intuitive, as Guest-WiFi should be more locked down and restrictive.
- Netduma-FraserJan 19, 2021NetDuma PartnerIt's the only place where there is a specific option to allow communication on the internal network, it may not work but it's worth a try.
