jjdresselhaus
Jan 18, 2021Aspirant
VLAN Tagging Prohibits LAN Communication & SmartConnect Issues
Resurrecting a problem that this post had -- https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-VLAN-tagging-making-wifi-devices-unable-to-communicate/td-p/1842061/page/3 Just bo...
Netduma-Fraser
Jan 19, 2021NetDuma Partner
That was with 'Allow guests to see each other and access my local network' enabled?
jjdresselhaus
Jan 19, 2021Aspirant
Thanks for double checking. Now it is -- and it's the same behavior as the normal network. So SSH fails, pings succeed.
- Netduma-FraserJan 19, 2021NetDuma PartnerIt may be worth you upgrading to the beta and then using Traffic Controller to allow ALL traffic to those devices, that may help them communicate with each other.
- jjdresselhausJan 19, 2021Aspirant
How stable is the Beta at this point?
- Netduma-FraserJan 19, 2021NetDuma PartnerIt still has some issues that we will resolve with more builds but it should be stable enough, you can always downgrade if needed.
- jjdresselhausMar 01, 2021Aspirant
Any chance on an update for this? It's pretty infuriating that my router can't route LAN communication properly...
- Netduma-LiamMar 01, 2021NetDuma Partner
Did installing the beta and setting a rule in traffic controller resolve this? If not, what results are you seeing now?
- jjdresselhausMar 02, 2021Aspirant
I did not install the beta. I would like a solution that doesn't involve running beta software in a production enviroment.
- Netduma-FraserMar 02, 2021NetDuma PartnerI will pass it on to NG, if they can identify the issue they may be able to provide a trial firmware with a potential fix but it wouldn't be a tested firmware - would you be willing to try that?
- jjdresselhausMar 04, 2021Aspirant
Sure! I would do that.
- Netduma-FraserMar 04, 2021NetDuma PartnerOkay thank you I have passed it on.
