jjdresselhaus
Jan 18, 2021Aspirant
VLAN Tagging Prohibits LAN Communication & SmartConnect Issues
Resurrecting a problem that this post had -- https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-VLAN-tagging-making-wifi-devices-unable-to-communicate/td-p/1842061/page/3 Just bo...
jjdresselhaus
Jan 19, 2021Aspirant
How stable is the Beta at this point?
Netduma-Fraser
Jan 19, 2021NetDuma Partner
It still has some issues that we will resolve with more builds but it should be stable enough, you can always downgrade if needed.
- jjdresselhausMar 01, 2021Aspirant
Any chance on an update for this? It's pretty infuriating that my router can't route LAN communication properly...
- Netduma-LiamMar 01, 2021NetDuma Partner
Did installing the beta and setting a rule in traffic controller resolve this? If not, what results are you seeing now?
- jjdresselhausMar 02, 2021Aspirant
I did not install the beta. I would like a solution that doesn't involve running beta software in a production enviroment.
- Netduma-FraserMar 02, 2021NetDuma PartnerI will pass it on to NG, if they can identify the issue they may be able to provide a trial firmware with a potential fix but it wouldn't be a tested firmware - would you be willing to try that?
- jjdresselhausMar 04, 2021Aspirant
Sure! I would do that.
- Netduma-FraserMar 04, 2021NetDuma PartnerOkay thank you I have passed it on.
