jjdresselhaus
Jan 18, 2021Aspirant
VLAN Tagging Prohibits LAN Communication & SmartConnect Issues
Resurrecting a problem that this post had -- https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-VLAN-tagging-making-wifi-devices-unable-to-communicate/td-p/1842061/page/3 Just bo...
Netduma-Fraser
Jan 19, 2021NetDuma Partner
It still has some issues that we will resolve with more builds but it should be stable enough, you can always downgrade if needed.
jjdresselhaus
Mar 01, 2021Aspirant
Any chance on an update for this? It's pretty infuriating that my router can't route LAN communication properly...
- Netduma-LiamMar 01, 2021NetDuma Partner
Did installing the beta and setting a rule in traffic controller resolve this? If not, what results are you seeing now?
- jjdresselhausMar 02, 2021Aspirant
I did not install the beta. I would like a solution that doesn't involve running beta software in a production enviroment.
- Netduma-FraserMar 02, 2021NetDuma PartnerI will pass it on to NG, if they can identify the issue they may be able to provide a trial firmware with a potential fix but it wouldn't be a tested firmware - would you be willing to try that?
- jjdresselhausMar 04, 2021Aspirant
Sure! I would do that.
- Netduma-FraserMar 04, 2021NetDuma PartnerOkay thank you I have passed it on.
