buffalo418
Jan 07, 2019Tutor
VLANs on Nighthawk Routers
Is it possible to setup VLANs within the OS of the XR500? Ideally create two networks that are truly separate from each other where devices on each cannot see or access each other. I see there is a...
Jan 07, 2019Guru - Experienced User
There is VLAN on my XR450:
VLAN / Bridge Settings
| Wired Ports | Wireless | ||
| (if required; range: 1~4094) | |||
Found under Settings/Advanced Settings/VLAN_Bridge Settings |
