Jamesfinn3
Jan 17, 2021Aspirant
Vodafone IPTV XR500.
Hi, has anyone managed to get the XR500 working for IPTV? I have replaced my ISP router with the XR500. Internet is working with Vlan10 but I can't get the Vodafone IPTV working.
- Netduma-FraserNetDuma PartnerIn WAN Settings toggle IGMP Proxying and see if that helps at all.
- Jamesfinn3AspirantNo good. Tried that earlier. I was looking at some posts on here from 2018 and I tried everything they had but no one seemed to have it figured for the xr500. Was hoping there had been a firmware upgrade to take care of this since.
- Netduma-FraserNetDuma PartnerDo you know if they require the use of their hub to use IPTV? If you disable QoS entirely does it work?
