Jamesfinn3
Jan 17, 2021Aspirant
Vodafone IPTV XR500.
Hi, has anyone managed to get the XR500 working for IPTV? I have replaced my ISP router with the XR500. Internet is working with Vlan10 but I can't get the Vodafone IPTV working.
Netduma-Fraser
Jan 17, 2021NetDuma Partner
Do you know if they require the use of their hub to use IPTV? If you disable QoS entirely does it work?
Jamesfinn3
Jan 18, 2021Aspirant
I found this on another platform.
it's for the ASUS RT-AC68U. This worked for Vodafone/Siro which is what I have.
Log into the router.
Left hand side click WAN
Connection Type PPOE
Username is the serial number (written under your gigabox) of your device (at)vfieftth.ie (eg e817dhnddbsggg(at)vfieftth.ie)
Password broadband
MAC Address. Also written under your gigabox. eg 4c:98:27:c8:a1:12
Click Apply
Left Hand side again click LAN
Click the IPTV tab
ISP Profile Vodafone (New Zealand)
Use DHCP routes RFC3442&Microsoft
Enable multicast routing (IGMP Proxy) Enable
Enable efficient multicast forwarding (IGMP Snooping) Enable
UDP Proxy (Udpxy) 0
I found this on the XR500 blocking iptv service thread here from 2019. I was hoping there was a firmware upgrade since to correct it?
I could not watch IPTV (Vodafone Spain) with XR500 and XR700, all attempts for iptv and ip voice with the valid configuration were a failure. The only thing that works by setting the operator's VLAN / Bridge was the internet connection.
I think it's a firmware problem, the configuration for operators IPTV in manual mode is basic.
I have an Asus RT-AX88U configured and working IPTV, internet data and IP voice for vodafone TV Spain and in less than 10 minutes everything was working perfectly ....... with XR500 and XR700 I was losing more than 10 hours and only I run data from the internet in the ports and in the deco but nothing from IPTV channels and IP voice.
I would like to put the Netgear as the main one but I can't do without TV and phone calls ... for the moment my main router is Asus.
- Netduma-FraserJan 19, 2021NetDuma PartnerThere isn't any profiles you could select for this unfortunately. TimChang could you take a look and see if there is a workaround or implement a profile perhaps?
- Jamesfinn3Jan 27, 2021AspirantThanks. Unfortunately I will have to look for another router so. Any recommendations on ones that can be set up for this?
- Netduma-FraserJan 27, 2021NetDuma PartnerI'd actively advising against our routers so it's not something I could do, have a search online for your ISP and I'm sure you'll find some.
