lushka
May 23, 2018Guide
VPN and Geolocation
Hey Guys,
Kinda new to this. Quick question. If I'm running a VPN connection via my router, is there a possibility to check my ping numbers for the lobby that I'm joining via the Geolocation R-app...
- May 23, 2018Hi lushka, with the VPN enabled the Geo-Filter will not work correctly. We're in the middle of testing our VPN Hybrid solution which may also resolve this issue depending on how it is used.
lushka
May 23, 2018Guide
Hi,
Unfortunately, it's not showing anything on the Geo map when the VPN option is active. As soon as it is switched off, I see all lobby members on the geo map.
Thanks
Netduma-Fraser
May 23, 2018NetDuma Partner
- lushkaMay 23, 2018Guide
Ok. Got it.
Thank you
