dfribour
Dec 20, 2021Follower
VPN extremly slow
Hi,
As soon as I enable VPN, my internet speed in 20x slower, going from 500 Mbps to 25 Mbps, both upload and download.
What is going on ? I understand vpn can reduce speed, but not by this magnitude!!!
Is there anything I can do with this router ?
try posting in the forum for your device. The DumaOS guys are pretty active on there.
- Netduma-FraserNetDuma PartnerThat's normal for the moment, we'll potentially implement Wireguard which will allow for faster speeds through the VPN. Would suggest you only put the specific application/service/ports through the VPN that you want to be protected so the rest of the device can get full speeds
