jam3s121's avatar
jam3s121
VPN for RDP?
I want to enable RDP on my windows compuer to the internet, but make it not exposed to the entire WAN. I believe the r6700 has a open vpn option. Is it possible to make it so only machines connected to the openvpn connection on the router are able to auth?
I'm using a netgear CM500 & netgear r6700. My goal is to be able to rdp from other networks but only when the other machines are on a openvpn connection. I believe I have to create the open vpn tunnel, enable rdp, and forward the port? I also want to change the port so its not default.
