jmc7
Apr 13, 2018Guide
VPN service settings
I enabled VPN service on the router and generated the .ovpn file for my iphone. When testing, I'm able to connect but before it actually connects, a window pops up regarding TLS certificate signed wi...
jmc7
Apr 13, 2018Guide
Ok, so when I enabled the vpn service, I left "clients will use this VPN connection to access" in auto mode. This setting apparently doesn't work correctly. After changing the setting from auto to All sites on the internet & home network, I was able to connect to my internal camera and now when I check ip on the browser, I see the ip of the router (isp) and not the cellular carrier ip address.
Still would like to know the issue with MD5 and openvpn no longer supporting.
