jmc7
Apr 13, 2018Guide
VPN service settings
I enabled VPN service on the router and generated the .ovpn file for my iphone. When testing, I'm able to connect but before it actually connects, a window pops up regarding TLS certificate signed wi...
JasonN
Apr 19, 2018NETGEAR Employee Retired
Hi jmc7,
I will forward this topic to my internal team and have them review it for consideration. :]
- Jason N
jmc7
Apr 30, 2018Guide
Today is the 30th of April. Is there a fix coming for openvpn? As I originally posted, openvpn is dropping support certificates signed with MD5 at the end of April. Well, here we are and no fix. I paid alot of money for this router and now a function I need will be broken. This is unacceptable.
- Netduma-FraserApr 30, 2018NetDuma PartnerI haven't heard anything, perhaps Jason can give an update on the situation?
- ErnestTheGreatJun 29, 2018NETGEAR Employee Retired
jmc7 The lastest FW 2.3.2.22 has the fix for MD5 OpenVPN problem. In FW 2.3.2.22 Netgear dropped MD5 support and replaced it with SHA256. Once you have the lastes FW installed you will need to delete the old OpenVPN configuration files and generate new ones.
- jmc7Jun 29, 2018Guide
This is great news and thanks for the update. I'll update the router as soon as I get a chance.
