Phantomblu
Sep 19, 2022Apprentice
VPN Setup XR500 V2.3.2.134 Problema
Good morning . I state that I updated to the last firmware XR500 V2.3.2.134 and I reset the settings, I set the VPN with the parameters I have in Purevpn, but I can't log in in any way. This from my ...
Phantomblu
The Setting in Purevpn and with Port Forwarding
My log with XR 500 on Purevpn VPN Setup:
VPN Setup
Attiva
Blocca traffico in caso di disconnessione della VPN
Mon Sep 19 12:16:52 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Sep 19 12:16:52 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Sep 19 12:16:52 2022 WARNING: No server certificate verification method has been enabled. See.... for more info. Mon Sep 19 12:16:52 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Sep 19 12:16:52 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:52 2022 Attempting to establish TCP connection with [AF_INET]5.254.88.170:80 [nonblock] Mon Sep 19 12:16:53 2022 TCP connection established with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 TCP_CLIENT link local: (not bound) Mon Sep 19 12:16:53 2022 TCP_CLIENT link remote: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Mon Sep 19 12:16:53 2022 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1560', remote='link-mtu 1552' Mon Sep 19 12:16:53 2022 WARNING: 'cipher' is used inconsistently, local='cipher AES-256-CBC', remote='cipher AES-256-GCM' Mon Sep 19 12:16:53 2022 WARNING: 'auth' is used inconsistently, local='auth SHA1', remote='auth [null-digest]' Mon Sep 19 12:16:53 2022 [Secure-Server] Peer Connection Initiated with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:54 2022 AUTH: Received control message: AUTH_FAILED Mon Sep 19 12:16:54 2022 SIGUSR1[soft,auth-failure] received, process restarting Mon Sep 19 12:16:59 2022 WARNING: No server certificate verification method has been enabled. See ... for more info. Mon Sep 19 12:16:59 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Sep 19 12:16:59 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:59 2022 Attempting to establish TCP connection with [AF_INET]5.254.88.170:80 [nonblock] Mon Sep 19 12:17:00 2022 TCP connection established with [AF_INET]5.254.88.170:80 Mon Sep 19 12:17:00 2022 TCP_CLIENT link local: (not bound) Mon Sep 19 12:17:00 2022 TCP_CLIENT link remote: [AF_INET]5.254.88.170:80 Mon Sep 19 12:17:01 2022 event_wait : Interrupted system call (code=4) Mon Sep 19 12:17:01 2022 SIGINT[hard,] received, process exiting Mon Sep 19 12:17:04 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Sep 19 12:17:04 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Sep 19 12:17:04 2022 WARNING:
VPN Traffic
Netduma-Fraser
Sep 19, 2022NetDuma Partner
I've responded to you here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/VPN-Setup-XR500-V2-3-2-134-Problema/m-p/2257631
